Results 11 to 20 of 27
- Aug 2011
- 374
January 6th, 2012 10:47 PM #11We can't see the pick. Right click then copy image location tapos paste the link here.
January 6th, 2012 10:50 PM #12
Here's the picture.
I hope umi sees this. He is, by far, one of the most knowledgeable detailers in our forum.
PS: LOL * voaquino's posts.
January 6th, 2012 11:10 PM #13
seems you have polished thru the clear coat. maybe not. need a clearer pic to evaluate if its just haze the compound you used is very heavy. a cleaner wax or a light polish will not be able to remove the haze created by 3m scratch remover. if youre from laguna area, i'll will be willing to check it out and polish it using a Dual Action polisher.
- Aug 2008
- 965
January 7th, 2012 04:08 AM #14Thanks Detailing's become something of a hobby for me, so I've tried to learn as much about it as I can.
Heh, masyado kasing nagpa-obvious, haha
Ouch. I'll have to concur with Ginnova, and say that it does look like you went through the clear - the dark outline that the delineates the polished area would seem to indicate that. Were you able to test if there's paint transfer if you try applying some polish to the affected area? You'll see color transfer to your applicator, like so (picture taken from this article):
If you're able to do so, take advantage of Ginnova's offer - I've seen shots of his work, and they're fantastic. Another place I can recommend would be Drive Bright in QC - talk to the owner, Gian, he'll be able to evaluate if you've gone through the clear.
- Jan 2012
- 16
January 7th, 2012 07:03 AM #15guyz how much do u think it will cost?.....nywayz im from cebu i wish i live near ur place to have it fix....tsktsktsk
January 7th, 2012 07:26 AM #16
maybe you could take a clearer pic. or did your applicator pad turned to the same color as your paint as umi mentioned then you have really striked thru the clear. repainting a panel normally cost around 2-3K.
January 7th, 2012 05:03 PM #17
Masyadong aggressive yung 3m Scratch remover. Ma fefeel mo talaga yung grits dun sa product pag nilagay mo sa fingers mo.
- Jan 2012
- 16
January 8th, 2012 01:07 AM #18actually bro nung ginamitan ko ng 3m scratch removal i saw dark markings s cloth...and i think na damage tlg ang clear coat...will dual action polish work gaya ng cnabi mo?...im thinking of taking it to a car wash and see if they could do something about it if not i guess i have no choice....repainting it will be my last resort...
January 8th, 2012 04:19 AM #19
you've striken through the clearcoat unfortunately and it will just continually grow bigger through the years. to fix you'll have to spot repair or repaint the panel. the very capable people from http://tsikot.com/forums/auto-painti...pintura-46122/ can help you with this.
January 8th, 2012 04:56 AM #20
the site search behavior has now changed, i found this advice for polishing using a mild polish. use even greater caution for aggressive polishing products.
http://tsikot.com/forums/auto-painti...ml#post1402103
When working SwirlX be sure to use a small product on the test area and work it with light pressure, once you feel the hard paint dead on between your finger tips or with your hand and the paint then you are already pressing too. Work SwirlX for a good 2 minutes and remove it with a MF towel to see if the correction done was already sufficient and if you are satisfied with the results. If the correction was done, then just duplicate this on the entire car. If the correction wasn't done, then re-apply the product again with light pressure, if its still there, re-apply it again this time with moderate pressure, but take note its always better to do multiple light passes as compared to few heavy passes, this way you only remove a minimal amount of clear coat from your paint, and by doing multiple passes you would remove just the right amount of clear coat that needs to be removed.
with enough arm pressure abrasion is possible even when using a non-abrasive substance. the substance may not be abrasive but the applicator material can be.
May nakita na naman akong ibang unit. Walang removavle cover but nung binutasab at binuksan, may...
2016/2017 Isuzu MU-X
