Results 731 to 740 of 2535
April 3rd, 2012 02:23 PM #732
Actually, it's pretty fine. I'm just more biased with Collinite's Sapphire Wax since that's what I use in conjunction with Collinite's 845. It's a pretty staple regimen for me as I've a white car too. I also believe that Collinite's Sapphire Wax has better cleaning properties (hence "whiter") than the Mothers but short of KAIO's cleaners.
If the car's under covered parking, every month - 2 months is fine. Really depends on how much the accumulated "libag" is hence I usually re-use Collinite Sapphire every 3 months or so para hindi sayang. As for the wax, OCW is pretty handy -- I love its ease of use, durability, and.. it's just good to look at. Simply re-apply every other week or every week depending if it's wearing off (look for beading, sheeting, etc. test)
April 3rd, 2012 02:30 PM #733
I'm assuming that's a 845 on top of a Nanoglos layer.
For reapplication, first check whether the old layer is worn out. Sayang naman kung okay pa yun prior 845. Look for beading, the less strongly it beads water then consideration should go to re-application. Or as rule of thumb, mga 1 month or so. (845 lasts me quite a long time so YMMV :D)
April 3rd, 2012 05:07 PM #734
thanks so much for sharing. so as not to waste what i bought, i'll use the Mother's cleaner wax first then change to Collinite sapphire. Some more question to which i hope you don't mind. Everytime i use the cleaner wax, should i apply the OCW after? And where can I buy Collinite products?
May 3rd, 2012 09:39 PM #735
mga guru's... in relation to the collinite sapphire wax.. what is better? Collinite Sapphire Wax or KAIO?
then planning to top it after with NanoGloss then Collinite 476/845 after curing.
(lapit na maubos cleaner wax ko.. need to level up na ulit.. for a better shite and protection :D )
May 3rd, 2012 10:31 PM #736
KAIO has very good cleaning properties. It's more versatile than sapphire. another plus point is you can use it as a base for either a carnauba wax or a sealant.
May 4th, 2012 11:15 PM #737
May 5th, 2012 10:02 AM #738
to simplify things eto ang suggestion ko.
KAIO ( no curing time needed ) + 845/476.
May 7th, 2012 04:32 PM #739
The thing with Collinite's Sapphire Wax is that it can serve as a standalone 1-step detail as it both cleans and protects unlike KAIO which only cleans.
However, KAIO's cleaning properties is definitely more potent.
May 7th, 2012 09:52 PM #740
KAIO cleans And protects. Hence the "all-in-one" name tag. A 1-step and also a last step product, its UV protection wins vs. CSW.
If you believe KAIO = Carlack 68 (NSC/PSC), NSC has a 30-40 minute curing time. If topping it with a product that offers no UV protection it's good to know and wait for this. I don't know the physics nor chemistry whilst prematurely wiping another non-acrylic type product over it. Disregard the cure time when following it with Carlack LLS/KSG and other compatible products.Last edited by indiej; May 7th, 2012 at 09:56 PM.
Xiaomi E-Car
