Results 1,661 to 1,670 of 2535
November 14th, 2014 03:46 PM #1661
- Oct 2008
- 213
November 21st, 2014 08:44 AM #1663
autopia/carcare-forum and autopia.org merged, bought by PBMG, owner of autogeek.
November 22nd, 2014 01:50 PM #1664
May nakapagTry na dito na gumamit ng Wurth Silicone Spray?
Para siya sa mga plastic and rubber part sa tsikot. Pang lagay daw sa mga platic part sa exterior ng kotse. Parang Armor All yata to. Hindi kaya nakakaCrack ng plastic at rubber yung Silicone?
Diba sa gulong nakakacrack pag may silicone yung tire black.
Parang ganito sya:
http://www.wurth.co.uk/data/productdocuments/070086.pdf
TIA
November 22nd, 2014 01:51 PM #1665
Parang ganito sya:
TIA
- Aug 2012
- 2,767
November 22nd, 2014 04:36 PM #1666Is there any particular reason why you want to use Wurth Silicone Spray? I have WD-40 Specialist Silicone Spray but I use it as lubricant.
Silicone Spray Lubricant & Silicone Grease | WD-40 Specialist
For detailing, I use Meguiar's Gold Class Trim Detailer for rubber and plastic parts including tires. Other products that you can try are Meguiar's Ultimate Protectant and Mothers Back-to-Black.
November 22nd, 2014 04:54 PM #1667
Bigay kasi bro ng dealer ko, freebies nila. Hindi ko nga ginagamit kasi hindi ko alam kung saan gagamitin yun pero last visit ko sa dealer, nagpaPMS ako. May nakita ako unit na irerelease nila, yung mga kulay itim na plastic part sa exterior eh ang kintab saka sa engine yung mga hose, wirings eh makintab din. Nung tinanong ko kung ano ang gamit nila, Silicone spray ang sinabi sakin.
Microtex Sunshield kasi ang gamit ko sa exterior part ng kotse, pero yung Silicone Spray mas maganda ang result, buhay na buhay yung pagka-itim ng plastic. Kaya natanong ko lang bro kung may masamang epekto kaya yung Silicone spray in the long run.
OT: nakita ko lang din pala sa Sunshield, Microtex Tireblack, Microtex Glaz No Squix, may silicone content din. Hindi ko lang alam kung saan based yung Silicone ng Wurth.
Kung may masamang epekto sa plastic yung Wurth Silicone Spray (ie., magcrack) eh hindi ko na lang siya itutuloy na gamitin, at kung kaya ng budget eh try ko bro yung Mothers Back-to-Black or Meguiars.
Thanks bro.
- Aug 2012
- 2,767
November 22nd, 2014 05:55 PM #1668I see. The safest advise I could give is to use it as lubricant spray (for car and home use) na lang. When it comes to detailing rubber and plastic parts, silicone spray is not the first thing to come into my mind. Meron naman trim detailers intended for the job that you can use without having any doubt.
November 22nd, 2014 07:47 PM #1669
November 25th, 2014 07:55 PM #1670
i tried the eagle one "nano wax"... base sa observation ko mas makunat siya keysa KSG...
the applicator foam pag tapos gamitin sa pag apply KSG, pag nilabhan ko, tangal na residue at wala n trace KSG.
the applicator foam pag tapos gamitin sa pag apply eagle one nano wax, pag nilabhan ko, hindi matangal residue at nandun pa din wax.
this is a better alternative dahil mas madali apply at i-buff yung eagle nano wax compared sa KSG.
hindi rin siya nag lilibag compared sa other waxes and sealants..
high idle RPM at engine start
