Results 1 to 10 of 11
May 6th, 2024 12:21 PM #1
All our vehicles are ceramic coated... later, naiisip ko if PPF is better
PPF is technically a plastic cover - so sya ang magkakaroon ng swirl marks instead of the car, in the end - may swirl marks pa din
Pansin ko na common gasgas ng daily drivers is sa parking (dings) and grocery carts. if naka PPF ako, di ba matutuklap yun kung madiin yung grocery cart?
Positive lang na nakikita ko is when I remove the PPF - 5 years later, I guess parang bago yung paint ng car/motorcycle ko.
Ceramic - 5 years later - yun na yun not unless I have the car color corrected - shop pa din naman gagawa since di ko naman pwede i-DIY yun
- Jun 2011
- 1,098
May 6th, 2024 03:08 PM #2Relative namin nagpakabit ng STEC PPF. Self healing daw sa mga scratches. Iyon lang $$$. Halos 200k yata para sa Kicks. Tapos tanggal emblems at door handles (pati door sidings tuloy), para mabuo ang panel films. Pati yata bumpers binaba din para abot sa panel edges. Kaka iyak bnew baklas agad. Hehe.
May 6th, 2024 03:57 PM #3
- Jun 2011
- 1,098
May 6th, 2024 05:15 PM #4
- Nov 2019
- 986
May 6th, 2024 11:37 PM #5
May 7th, 2024 11:26 AM #6
Durable or not ... it's not going to add 100T-200T to your vehicle's resale value ... may be ok for vehicles worth 10M or more ...
- Jan 2007
- 2,251
May 7th, 2024 11:44 AM #7Yeah 200k is too much, even for a car worth 2M, let alone 1-1.5M like most econoboxes.
Ceramic coat is 15-35k I think? Should be good enough. You can re-do it every 3-5 years and still be significantly cheaper than PPF.
Or a good washover for 50-75k after 10 years of owning the car.
May 7th, 2024 12:31 PM #8
minsan naiisip ko... how's PPF when it comes to hard water?
may case kasi ako dati halos 1 month (4 car washes, 2x wax) bago completely natanggal yung watermark ng (ceramic coated) car ko
- 170
May 12th, 2024 05:32 PM #9
... perhaps the workers have been replacing the worn welding tips as a matter of routine, without...
Chery returns to PH
