Results 11 to 16 of 16
- Jul 2011
- 71
July 30th, 2014 12:46 PM #11
July 30th, 2014 04:21 PM #13
After confirming no coolant loss, this was the time the dealership installed a seal to prevent tampering and to preserve integrity for warranty claims. No, do not mix coolants. There are ethylene glycol based, propylene glycol based, Hybrid organic acid technology(HOAT), organic acid technology to name a few. They are not exactly compatible. Each formulation is designed exactly for the metals, composites and sealing materials used in the engine. Failure to install the right antifreeze/coolant mixture or the right type shortens the life of the engine. Avoid the "pwede na yan" coolant.
Posted through phlpost.gov.ph
- 52,700
August 1st, 2014 01:44 AM #14i think a simple rule to remember is, "do not mix coolant colors".
Posted through phlpost.gov.ph[/QUOTE]
- Jul 2014
- 162
August 1st, 2014 03:43 AM #15Tama yan mga sir pure coolant ang maganda lalo pag Toyota or ford coolant.. Ligtas ang cylinder head at engine block sa kalawang.
Tsikot Mobile App
- Aug 2005
- 553
September 28th, 2014 11:45 AM #16
