Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    May 2012
    Good evening mga sir. Possibleng may leak daw sa evaporator yung 2006 vios namin. According sa mga nabasa ko, ok na daw pamalit yung mga aftermarket evaporator, kahit anong class, as long as hindi yung locally made. Yung iba naman sabi mag-oem na kung kaya ng budget.
    Questions:
    1. Gaano ba kalaki ang difference ng oem vs imported aftermarket evaporator in terms of tibay at cooling effect?
    2. Any idea sa estimated price ng oem? Meron ba sa banawe nito or available lang sa denso kapag dun nagpagawa?
    3. Pareho lang ba kapag sinabing oem at laminated? replacement at aftermarket? (Paki-clear kasi nalilito ako)
    4. Quote kasi sakin 8.5k all in, laminated (note: tanggal dash). May naka-try na kaya na bumili na lang sa labas ng evap then pakabit sa shop para cost lang ng aircon cleaning(2.5-3k)?
    Sana may makasagot. Marami na ko nabasa dito pero wala kasi ako makita tungkol sa oem evaporator.
    Nov 2007
    1.ala masyado diff..maliban kung hindi marunong ang titingin..size,coolingfins at ang space nito.
    2.meron mga pwesto sa banawe.
    3.hinde..oem orig parts..ibig sabihin stock..laminated isang klase ng coil..exp sa ibang unit meron din tinatawag serpentineo di kaya yung fabricated.
    4.pm kita.
    Aug 2005
    Will change to after market evaporator.
    May 2012
    Ito sir sa 2003 altis mga year ago
    Sa denso q ave
    Evap 9,236
    Exp valve 2,250
    Drier 1,650
    Labor cost 2,500
    Dont know kung parehas sa vios pero palagay ko malapit
    May 2012
    Quote Originally Posted by SiPS View Post
    Questions:
    Mura na ung 8.5k sir kumpara sa denso all in all sa denso mga 19k palit evaporator drier and expansion valve. Buti ung akin noon ok pa evaporator askmo din kung pwede lagyan ng cabin filter ung akin pinalagyan ko
    Aug 2005
    As long as they are both warranted there shouldn't be much difference.
    Tubing, fin pitches, and all material gauges remaining the same of course.
    when my innova's rear evaporator sprung a leak, i initially asked for aftermarket, because it was cheaper. alas! it did not fit the plastic frame. i had to buy the OEM..
    Jul 2012
    on our 06 vios, inabot ng 12k. palit oem evap, freon, oil, yung fitting na nakadikit sa evap, drier, etc.. etc.. labor.. labor..
    May 2012
    Quote Originally Posted by enzo6k View Post
    Saan yan sir sobra pala talaga mahal sa denso he he.
    Aug 2005
    Eto estimate sa akin
    evaporator: 4,500
    eepansion valve: 1,400 each. 2x. kaya 2,800
    aircon cleaning: 3,000
    others: freon, oil, etc
    total ay 11,000.
    evaporator: 4,500
    total ay 11,000.
    had a leak in my evap and this was temporarily fixed by welding the hole. im planning to replace the original (DENSO, i think, civic 99) evap soon.
    I qot a qoute from an ac shop of a Taiwan replacement evap, i dont know the brand they just labeled it serpentine worth 2k. Would you recommend this?
    the original DENSO evap cost around 6.5k.
    thank you
    Aug 2005
    Quote Originally Posted by poorprince View Post
    thank you
    If buying OEM make sure it is original not rebranded.
    It is difficult to tell which A/C parts are reliable or not on the surface. Some manufacturers value engineer their products by using thinner materials or lowered fin pitches just to get eke out more margins. And these are pretty hard to detect by just looking at the item.
    One way but not foolproof is to weigh the part. Heavier normally means more material. And given high pressure conditions, thicker materials will normally withstand fatigue longer.
    Be mindful of fin symmetry and weld joints as well. It is a good hallmark of how a manufacturer values quality.
    ~ 13 year old honda crv 2.0 liter 4wd
    after ~ 13 years biglang one day ayaw lumamig ang aircon. busy ako so my relative who is an amateur mechanic had it fixed at a local car aircon shop owned by his friend. Butas evaporator. cost to replace was 6000 pesos, lahat kasama pati labor and parts and freon. Now noticably mas mahina ang aircon specially pag naka park sa nooontime sun and not moving. Pag cloudy days or gabi or running at highway speeds pwede na. I have to assume na pangit ang linagay na evaporator, kaya nga mura
    i can only hope siguro na madali mabutas uli and next time ako nalang ang magpapa ayos. magkano kaya ang magpa replace ng evaporator ng CRV first gen using quality parts?
    Quote Originally Posted by vmaldia View Post
    ang alam ko sa mga Honda, uso yung gumagamit ng JDM evap. noticeably mas malamig daw ito compared to OEM na galing local.
    Aug 2005
    There's a good chance the evacuation and charging of the refrigerant loop was not done properly. I suggest you have this checked.
    If there's the tiniest amount of air in the system, it will degrade performance.
    Jun 2006
    Yung laminated type na evaporator has mor contact fin areas, halos kamukha ng orig ito, mas mabilis at malakas lumamig.
    Compared sa oem na pure alumimun lna paikot ikot( same type na gamit sa a/c ng bahay), hilaw lumamig at pag tirik ang araw matagal palamigin ang oto.
    Oem ang kinabit ko sa corola ko worth 1.5k compared sa laminated na 2k halaga. Baklasin ko ulit at paltan, di ako natutuwa sa lamig.
    Quote Originally Posted by shibby75 View Post
    same here. the more expensive laminated design evaporator costs more than serpentine, but it does cool significantly better. worth the extra cost, in my opinion.
    Jan 2012
    -laminated evaporator 3,500
    -Serpentine evaporator 2,500
    -local evaporator yun maraming tubo na paikot-ikot 1,500
    konti lang ang deference mamili ka sa laminated and serpentine type pareho lang orig yan, basta wag local...
    Aug 2005
    Do you have a photo of this local evaporator?
    Quote Originally Posted by EVO-V View Post
    want to see how this local evap looks like to.
Oem evaporator vs aftermarket evaporator
