Results 1 to 5 of 5
- May 2013
- 38
September 19th, 2014 08:17 AM #1Hi guys,
Ano kaya problem ng A/C ko na maingay ung fan / buga ng hangin pero malamig naman?
Thanks!
September 19th, 2014 08:35 AM #2
Baka kailangan lang ng Linis or spray ng lubricant/WD-40 yun motor.
Posted via Tsikot Mobile App
September 19th, 2014 12:43 PM #3
madumi lang yan.... same as the regular electric fans baka may dirt accumulation na sa blades o sa mismong motor.
linis lang yan.... an reputable aircon shop can do it.
pwede din DIY yan kung matyaga ka.
September 22nd, 2014 12:46 PM #4
Check your cabin filters. Most likey clogged na. You can blow compressed air to remove dust.
- Aug 2014
- 10
October 29th, 2014 06:49 PM #5Correct, its just the cabin filter that is clogged and dirty. It also happened to me, the #2 fan setting is so weak and noisy., then I tried to remove the cabin filter and try it again, then the noise and weak air that comes out of of the vent gets back to normal. I suggest you replace the cabin filter.
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
