Page 4 of 11 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 102
  1. #31
    Join Date
    Dec 2009
    Default Re: Car Aircon Problem
    Quote Originally Posted by aldwindavid View Post
    Need your advise guys, had my aircon cleaned by a nearby car aircon technician. They replaced the bearing kasi maingay siya, palit drier, expansion valve, linis evaporator, karga freon. Nawala naman yung ingay and aircon was working fine. Pag uwi ko sa bahay nawala yung lamig. Balik ko sa shop and the compressor is not engaging. Checked everything (freon, etc.) pero wala namang makitang sira including fuses. Nirekta yung compressor and umandar and lumamig siya. Since gabi na and agreed with technician to go back the next day, pag uwi ko before reaching our house gumana na naman yung compressor. Lamig ulit. The next morning ok siya. Unfortunately di na ulit gumana yung compressor when I used the car in the afternoon. this morning di na naman gumaganana yung compressor. Di ko na binalik dun sa aircon shop kasi di na alam nung technician ang gagawin.
    What could be the culprit behind? Dinala ko siya kahapon ng umaga sa Cee Jay, unfortunately di naman nagluko. Almost an hour they observe the car, but di naman nagluko. Ill bring it back sa Cee Jay sa Friday and have it checked there. They advise me to leave it there for the whole day para obserbahan in case the same happened again.
    Car is Nissan Exalta 2004 pala.
    We have the same problem, sometimes it engages and sometimes hindi. I'm trying to look for a good shop to bring it in for diagnosis/repair. Were you able to have it repaired na? Baka pwede mo naman ishare kung saan and how much it costs? thanks!
  2. #32
    Join Date
    Location
    Laguna
    Finally my aircon is working fine right now. The culprit was a busted thermostat. They replaced it with a manual type and it worked.
    It costs me 400 pesos for the thermostat. Mang Mario's technician diagnosed and found the culprit.
  3. #33
    Join Date
    Location
    laguna
    sa case ko mga bossing.,, pag-bukas ng a/c may maririnig kang squeak.. may nagsabi bearing daw un.. makanu kaya cost nun?? (Kia PRIDE CD5)
  4. #34
    Join Date
    Sep 2010
    Location
    valenzuela
    sir saan yong shop ni Mang Mario
  5. #35
    Join Date
    Apr 2009
    Car aircon problem, normal po ba na pag engage ng aircon naa pektuhan ang RPM ng engine? in my case tumataas. and for some reason nag fluctute ung pag engage ng aircon ko, parang on,off, on, off.. what could be the problem, please help
  6. #36
    Join Date
    Sa kin naman, malamig sa umaga, pero kapag tanghali na, mainit na ang labas ng hangin. What seems to be the problem kaya?
  7. #37
    Join Date
    Mga Sirs: nag re-rewind pa ng clutch coli ang CEE-JAYS? Experienced ko kasi sa HONDA CITY idsi kapag start ko sa umaga ok ang lamig ng aircon. Laging ganun pero kapag na tatrapik na ko nawawala yung lamig.
    Pinatingin ko somewhere in cubao, clutch coil rewind daw kailangan mga magkano ba dapat ito?
    advise naman mga sirs
  8. #38
    Join Date
    Nov 2007
    Location
    qatar
    Quote Originally Posted by quedee View Post
    paandarin mo makina at a/c..tap[os buhusan mo ng tubig..pag nawala maaring fanbelt ito..at isa para malaman ay pag on lang ba ng A/C meron?
  9. #39
    Join Date
    Nov 2007
    Location
    qatar
    Quote Originally Posted by jayardingo View Post
    maaring high pressure na system ng a?c mo..
  10. #40
    Join Date
    Nov 2007
    Location
    qatar
    Quote Originally Posted by balasador View Post
    sa honda sir maaring sira aux fan mo o medyo mahina na..at isa pa kinabitan ba nila ng guage para sa high at low side?kasi sa ngayon yung ibang shop hindi sila marunong bumasa sa high side..sana nakatulong
Posting Permissions
  • You may not post replies
  • You may not edit your posts
