Page 23 of 59 FirstFirst ... 1319202122232425262733 ... LastLast
Results 441 to 460 of 1163
    #441
    boeing: ai, kotse...
    ***edit***
    ay, teka, not sure sa ai. fo'sho sa kotse though.
    Sep 2004
    #442
    Quote Originally Posted by OTEP
    Just don't use a higher rated fuse, yun ang delikado. Worst thing that could happen with a lower rated fuse is you'll bust the fuse again.
    But the best is still using correct fuses. Ginagawa ko lang iyan kapag wala talaga kong mahanap na tamang fuse (like the other day).
    uh oh ... came from mang mario the other week and this was exactly what the guy told me to do. get a 15amp fuse to replace the 10amp fuse that got busted.
    #443
    i agree with using the same, or in extreme cases of inavailability, a lower fuse. that way, safe ka pa kasi with a higher-rated fuse, mas maraming current na dadaan before the fuse blows out to protect the circuit, so greater ang potential for damage.
    Sep 2005
    #444
    mga bossing ask ko lang.... may funny smell ang aircon ng pajero ko (parang amoy pawis) specially pag bagong on.... i checked the carpet hindi naman basa... i checked the condenser (yung may window for the freon flow) hindi naman bumubula so ruled out na ang low freon level.... nag lysol ako kagabi and even applied leather care sa seats, ganun pa rin... help!!!
    #445
    malapit na ako pumunta kay legendary mang mario...maingay na bearing ng aircon compressor ng honda ko...
    #446
    Text mo ko chieffy, baka nasa area lang ako. Kapag Thursday, nasa area lang ako. Usually, SM City or Wilcon.
    Jul 2005
    #447
    Quote Originally Posted by pajojo
    pag r134a gamit ng oto mo probably may leak yan cooling coil mo . madalas pag bagong on ang ac saka lang malakas ang amoy yan ang symtoms ng leaking c.coil
    Sep 2005
    #448
    Quote Originally Posted by chieffy
    ako rin maingay na yung compresor. saka nag-high pressure na yung aux fan ng aircon. magkano kaya pagawa nito?
    #449
    Yung ingay sa compressor depende sa source (e.g. bearing, shaft, clutch, etc.). Yung replacement surplus aux fan Php1,500.00 SRP nila. Yung kinabit sakin DENSO din same as my damaged motor.
    Nagkakaron lang ng additional labor charge kung mahirap kunin yung aux fan. Tipong baklas bumper, etc.
    Kung papa-repair mo, nasa Php400-500 ang range nowadays.
    Jul 2006
    #450
    me prob po ako sa corolla aircon ko
    kapag mainit hindi sya lumalamig, pero kapag malamis (kapag umuulan malamig naman sya)
    hindi pako gaano kabisado parts ng sasakyan kasi almost 6 months ko pa lang nahahawakan to.
    napapansin ko:
    umaandar naman yung compressor, nagwhi-whistle pa yung refrigerant (r-134a)
    tapos kapag tumagal tagal nga, (depende sa climate) ganun status ng aircon ko.
    OT:
    nagaayos din ba sila sa steering?
    kasi problema ko, ang hirap na iikot yung manibela, pero wala naman leak.
    anu kaya problema? sabi nila pump daw... pero gusto ko na rin ask sa inyo.
    thank you po.
    Aug 2003
    #451
    sigurado if you go to mang mario they will change your dryer
    Sep 2005
    #452
    OT:
    aircon repair lang po sina mang mario.
    Jul 2006
    #453
    have a good learning expierience with mang mario lately.i have a busted compressor when i forgot to replace my old dryer when it was cleaned, so nagbara sa drier lahat,tendency ng compressor is to work hard kaya ayun bumigay..i went to mang mario to have my compressor changed, he suggested a conversion(denso) since mahirap daw makahanap ng orig(calsonic) surplus para sakin.they made a good convertion though.but when i went up north ive noticed an annoying squeaking sound sa fan belts all the time.tried to tightened the pulleys 3 times pero ganun pa din.and one more thing,umiba hatak ng oto once na mag idle up na un a/c. parang bumagal compared sa nkalagay dati..now this is how i appreciate mang mario. i called him up and told him about the flaws(?)..and i honestly said na hindi ako satisfied,maybe dun sa pag convert. know what, he asked me to come over sa kanila.they checked the car,funny hindi lumabas yung squeak pero mang mario did a good gesture of returning my P7,500, at tapos ibinalik nalang sa dati yung compressor ko..i was happy and a little ashamed kasi nga nagsayang lang kami ng oras. but he said,"di naman natin pwedeng ma-please lahat ng tao eh"..well that's true, but stil i'm pleased with him kasi binalik nya walang labis walang kulang yung binayad ko dati..right now, i've changed my compressor back to the original(found it in evangelista,pasay),and even bought a new belt at ayun,gumanda na takbo.. pero one last question, baket may ingay pa rin yun fan belt?...WAAAH! (pero nato-tolerate ko naman na)
    May 2005
    #454
    Bro, check mo kung naka align ba ang Pulley mo or check mo din ang tension ng belt.
    #455
    Baka luma na yun fan belt mo? I have the same problem now, and same thing when I went to Mang Mario to check the noise e nawala, but then pag uwi ko nandun na naman. I think kasi luma na yun fan belt ko, papalit ko na but wala pa yun parts.
    #456
    Quote Originally Posted by wateewawee
    baka nakakarating na sa kanila yun mga reklamo, kaya medyo nag iba ng strategy si mang mario, di kaya ?
    #457
    Quote Originally Posted by red888
    tatlong beses ko na nakaharap si mang mar, nakakwentuhan ko na rin nung first time ko magpa-ayos sa kanya... and pareho pa rin impression ko sa kanya. mabait na tao na di manloloko... treat him with respect and he'll give that respect back... give him bullshit and he'll bullshit you back too. madiskarte, pero umaamin naman kung di na nya kayang diskartehan.
    May 2005
    #458
    Quote Originally Posted by seonadancing
    Bro Seona,bago naman daw ang belt sabi ni Wateewawee,sa naexperienc eko noon nag palit din ako ng bago iyon pala kulang pa sa tension ang belt kaya mejo may ingay pa
    #459
    oki dok...itataon ko ng Thursday...text na lang kita...bumubuwelo lang ako ngayon at wala pang pang repair he he...
    #460
    Baka naman may anti-noise force field kina Mang Mario kaya nawawala.
    Ako naman nangyari sakin, pagkaalis ko kina Mang Mar (after repairing the Sentra's resistor), pagdating ko dun sa main road biglang nawala lamig ng a/c. Pucha, ikot ako pabalik kina Mang Mar. Kapag malapit na ko sa kanila, biglang lumalamig yung a/c! So akala ko ok na, balik ako sa main road. Pagdating ko ng main road, WALA NA NAMAN! Mga nakatatlong ikot ako bale. Nung pangatlo, sabi ko bahala na kahit lumalamig diretso pa din ako sa bahay nila.
    Turns out that stuck up yung compressor, kaya nung paakyat ako papuntang main road naiiwan yung compressor (therefore hindi lumalamig), kapag pababa naman ako and hindi mabilis ang revs, nakakasabay ulit ang compressor (lumalamig ulit). Kala ko minumulto na ko, eh. hehehe. Buti na-diagnose ni Norman.
    Ang kaso hindi pa din approved yung funds para dun sa repair (red tape) kaya hindi ko pa nababalik.
    Sige chieffy, balitaan mo ko. Try ko na lang na sabayan ka.
Aircon Repair: Mario Reyes
