Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 173
    Jun 2012
    Ask ko lang, kanina pag gamit ko hindi masyadong malamig ung buga ng aircon though naka todo na ung thermostat at naka 3 na ung fan then nung nasa highway na nung umarangkada na ko dun lang lumamig ung aircon. may problema na kaya aircon? 2012 gls v montero pala ung unit. thanks.
    Quote Originally Posted by mar04 View Post
    Check aux fan.
    Aug 2004
    Pansin ko rin yan sa Vios ko. Normal temp pag nakatigil sa traffic. Biglang lalamig onti pag andar na. Heat soak siguro di kinaya ng fan ang init.
    Sep 2012
    I'll send it ulit sir sa Frigid Zone, papa check ko yun compressor. Di ko kasi naasikaso this past few days kasi ginamit ko un SUV since puro bagyo.
    Baka nga may tama na rin yun compressor, actually kakakuha ko lang ng engine this month din, its a surplus B18C-R. I'll probably have it tested since the engine saw a little high mileage narin.
    Sep 2012
    Quote Originally Posted by Dexdrex View Post
    Just an update, di ko kasi naasikaso un Civic ko last year bali I brought it to another shop. Chineck nila everything ok naman daw mga components, nakita lang medyo mababa daw yung oil ng compressor and they changed it the oil, They called it capella oil if im not mistaken and they cleaned the AC System narin. I used the car today and parked it under the sun kanina, nung bumalik ako sa kotse around 12pm, hirap parin un aircon palamigin un sasakyan.
    Apr 2014
    Mga tsikoters,
    I need you suggestion , kapag tanghali ang hirap lumamig ang kotse ko kahit naka todo na aircon, ok naman sya kapag umaga and gabi kapag ndi mainit panahon... Ano maganda pagawa ? Paplinis aircon?
    Kotse ko is civic 1997 vti. Salamat!
    Posted via Tsikot Mobile Ap
    Quote Originally Posted by Jeff2308 View Post
    Mga tsikoters,
    1. kulang freon.
    2. mismatched aircon components.. my guess, your evaporator.
    3. aux fans are slowing down.. replace them with new ones.
    good luck.
    Apr 2014
    1. kulang freon.
    good luck.
    Thanks Dr d sa inputs!
    Jan 2003
    IMO, they should have checked the condition of the compressor prior to replacing all parts. Because if di na maganda ang bomba ng compressor, useless din yung new parts.
    Posted via Tsikot Mobile App
    Jul 2014
    How much did it cost you?thank you.
    Apr 2011
    ipapacheck ko narin ac ng auto ko. (Mitsubishi Adventure, Diesel `98)
    hindi kaya ng ac kapag mainit ang panahon, and kapag bagong start hindi kaagad lumalamig.
    pero kapag gabi / cloudy / umuulan, ang lamig ng aircon.
    ano kaya problem neto?
    Quote Originally Posted by ironvin View Post
    kulang na yan sa freon due to leakage.
    maaring may leak nasa evaporator, considering the age of your vehicle
    Apr 2015
    Mag pa linis ka muna ng aircon... Pa check up mo. Parang aircon din yan sa bahay dapat linisan.
    Sep 2012
    Quote Originally Posted by AnthonyMe View Post
    As stated,
    Feb 2012
    Mga sir anu sa tingin nyo kung gagawing 3 condenser yung van ko may ilalamig pa kaya?
    Apr 2012
    pa help naman po, Isuzu trooper bighorn model 99 ung akin, 4jg2.
    napalitan ko na po ung
    receiver drier
    Zexel compressor
    expansion valve
    front evaporator
    cleaned AC system
    pero hilaw pa din po lamig nung auto ko. kahit linisin ung condenser.
    kelangan ko po bang palitan na din pati condenser? thnks
    Sep 2008
    Quote Originally Posted by mosplinar View Post
    receiver drier
    Zexel compressor
    expansion valve
    front evaporator
    cleaned AC system
    Assuming that all your parts that was replaced are all in good condition, meaning walang factory defects, and both high and low side lines are in optimum range, I would think that the problem maybe in your freon. Madami kasing freon ngayon na below standard, ergo, hilaw ang lamig ng aircon
    receiver drier
    Zexel compressor
    expansion valve
    front evaporator
    cleaned AC system
    Also advice ko try to watch sa youtube or google kung paano mag interpret ng HVAC Manifold Gauge, Marami kasing lokong aircon repair shop, gusto palit lagi pag nag repair
    Jun 2008
    Bago palitan ang condenser bakit di subukan linisin muna then add auxiliary fan para lumamig ang condenser. A surplus aux fan will do.
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    May 2019
    Ano po kaya pinaka the best na compressor for lancer boxtype SL 4g33 ? Namamatayan kasi ako ng makina kapag paahon ang daan. Salamat
    Sent from my Flare S5 using Tapatalk
Aircon di kinakaya pag mainit
