Page 5 of 21 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 413
    #81
    Quote Originally Posted by yudyin View Post
    swete naman ni balu. anong oras po ba nagbubukas sila mam cora? tsaka open din sila tuwing weekend diba?
    they are open from 8 am-6pm including weekends.
    they do give reasonable discounts even though your name is not posted on their wall....
    Nov 2007
    #82
    thanks 1d! one of these days i'll go there! :P txt ko muna sila or tawagan baka kasi pagdating ko dun madaming tao
    #83
    much better if you can go there before 8am so you will be done by 10-11 am. minsan talaga napupuno sila.
    Jan 2008
    #84
    i tried Ceejay's service today to have one of my vehicles air conditioning cleaned to see the feedbacks i've been reading here in forums and here is my review..
    Craftsmanship +1 = very nice work, dedicated and detailed to the job being done.. they even replaced some o-rings and foam insulations.. Job finished within 3 hours.
    Cleanliness +1 = they are using the proper tools and covers to keep the vehicle clean and avoid dirt inside the vehicle while working. But I noticed the workers do not wash their hands first before working on the vehicle.. my car is white so grease is very visible and during their first inspection my door handles got grease and oil... They cleaned it after the job..
    Environment -1 = I found Ceejays shop is NOT "Environment Friendly"... They do not retrieve CFC or HCFC from the units they will be working on.. They just let it out thru the AIR (using water in a small container). They should invest on this one considering they are doing aircon cleaning jobs more than compared to other shops nearby.
    Overall, I'm satisfied with the job done with the vehicle... But to be the best shop in the aircon service they should also consider the environmental effects of HCFC and invest on the technology of retrieving and recycling these harmful gasses..
    BTW: some shops already have the CFC/HCFC retrieval equipment..
    Nov 2007
    #85
    Quote Originally Posted by 1D4LV View Post
    so mga what time yun 1d? baka sa monday morning punta ako
    #86
    subukan ko rin ito sa sunday... on my sentra...
    #87
    Try ko dito. PTF-763 ang plaka. Discount ah. I'll post my feedback soon.
    #88
    Quote Originally Posted by SunTzu View Post
    sige bro. try mo.
    imho and suggestion lang. try mo din ipa accredit yung MMPH bro.
    #89
    i tried * ceejays this morning bago man lang ang laban ni pacman... la ako masabi...i'm so satisfied.... ang bilis ng trabaho... after the job, final inspection ni joel...
    pwede ibalik after 1 week for check up...
    maski malayo konti, sulit naman...
    may discount pa ang tsikoteers... aside from 10%, may add-on discount pa kay cora...
    Apr 2005
    #90
    had my Isuzu Fuego cleaned last Sunday. Good work done! This is the first shop that didn't try to have anything replaced unnecesarily. Most shops will have you replace your expansion valve and drier even if it is not necessary.
    Just had my evaporator cleaned, and my system is as good as new. I have one complain though, the evaporator or its housing was not rinsed enough, my ride smells like laundry detergent until 2 days later. I hope the smell will be gone in a couple of days.
    Overall, I'm satisfied with the service, and will go back to them for future repairs.
    #91
    ^^ it will be gone after a week or so. ganyan din ang nangyari sa akin.
    although nanenegate nung smell if you would use an ionizer or charcoal.
    Apr 2005
    #92
    dami ng fans ng ceejay's! I'll try them on my next aircon cleaning.
    May 2008
    #93
    i have read all the posts in this thread. magaling nga ata gumawa sa ceejay's. puro positive mga nabasa ko kasi e. i will go to ceejay's pag nasira ang a/c ko. or for cleaning.
    Quote Originally Posted by bigfoot View Post
    laundry detergent ba iyon? hindi ata eh kasi i had my ride serviced there twice before & it seems like its sop. i just don't know what it is they're using
    #95
    salamat po sa thread na ito!
    em from laguna. this is a real big help. lalo na sa gaya ko na sakit din ng ulo ang A/C sa awto.
    salamat!
    #96
    andun ako kanina. mga 1 PM.
    galing kasi ako ng manila. by the time i left home at 9 am, i noticed that my ac is blowing hot air, while kagabi naman ok pa sya. it is much worst when i am going home during lunch. parang sauna yung loob ng oto ko.
    since ceejay is just 5 minute drive from home, i decided to drop muna here to have my ac checked. upon checking they found out na wala ng freon. but since april lang ako nagpakarga, definitely may leak. physical inspection proved nothing. hindi makita yung leak.
    nung pinabaklas ko na, nakita na may malaking butas sa cooling coil. no choice except to replace it. palit expansion valve na din tsaka receiver dryer. libre na palinis dahil two months ago lang last nilinis.
    cost me a lot... hehehehe, but well worth it. may discount naman eh... tsaka malamig na ac ko.
    ill be back next week for the checkup.
    kudos...
    #97
    sige bro. try mo.
    Yup, I've already talked to Joel about MMPH accreditation. Thanks bro.
    Magaling nga sila. And yes, they use GENUINE freons. Malaki ang difference ng lamig sa fake.
    #98
    yup!!magaling talaga dito sa ceejay's..bait ng may ari..nagpaclean ako ng a/c ko the other day..tapos today nawala lamig..yun pala bumigay na pressure switch ko..nagkataon lang siguro na bumigay..hehehe overall satisfied pa din..
    #99
    #100
    ^^ dami mo pera bro ah.. puro pagawa ng oto ah. hehehehe.
AC repair shop in Las Pinas area
